Continued,
Saturday POTD was breaking the toe plates (1/8"x 7" x 14"). I used a pre WW II manual apron break for this operation. I sheared three 20' lengths and have extra.
Finally started welding after three full days of cutting. Started with the axel assemblies and legs.
The jig is compact and used for main frame, axel, leg and toe plate. It is drilled and tapped at the axel end to accept an add-on axel jig for larger 16" tires for our R/T (rough terrain) model.
The hub is 16 gauge 3/4" round tubing that fits snugly over the 5/8" CR axel, The axel assembly is 1/4" x 1" flat bar. The pulse mig is set at 230 IPM and a hot fast weld is required to weld the two different sized materials. If you dwell too long you'll burn through the lighter tubing.
A shot of the axel jig.
After burning though the axels, next up where the legs. The square tubing (14 gauge x 1" x 1") is welded to a 3/8" x 1' flat bar. The mig settings for this was 250 IMP. Same deal, HOT and FAST. Theres a little gap to ensure penetration. The legs where then cleaned up with a 2" roll-loc knocking off and stuck dingle berries. For those who have never used a pulse mig, they are fantastic for leaving a hot clean weld.
The last task for Saturday's POTD was to drill the toe plate tubing (16 gauge x 3/4"x 3/4") and de-burr the inside/outside hole. This hole is where the S/S snap push button will live once fully assembled. The button needs to sit flat and free of burrs for a reliable operation. Back in 2003 when I first started these, I used to use a small bremel grind stone and it took for ever. The ZIT-Burr is awesome and fast. I'll try to remember to get a shot of it for those who might need a clean hole in tubing. I run it at 350 RPM and it leaves a clean slightly chamfered (both sides) hole.
Sunday's POTD was to weld the main frames and toe plates. This took about 10 hours with no lunch break.
Here's some detailed shots of the jigged frame.
The cool part is of the jig design is the clamp points. You notice some points are thicker (cross bracing and end). This allows for all the clamps to be adjusted the same saving time adjusting for different material thickness. Once the frame is welded the clamps are piled up in the middle awaiting the next frame and BAM! you clamp them up regardless of which clamp you grab. I do stop production after 6-8 frames to vacuum the jig to keep things flat. The frames sit 1/4" off the table allowing complete vertical welds. You can also see the way the stock is stored for fast easy access.
Next up for Sunday's task was welding toe plates. Same jig different area. The 16 gauge is welded to the 1/8" toe plate with a complete weld. The machine was set to 215 IPM.
You can see the heat zone on the backside of the plate. The square tubing was beveled to accommodate the break radius. All seams on tubing facing down (including the main frames).
A close up of the joint. A tack weld at the bevel (first) prevents a burn through. Then run fast on the three sides. Unclamp and flip to weld the bottom.
This bring us to today's POTD. Cleaning the main frames for preparation of welding the axel and leg. This is my least favorite task as I use a N-95 mask and grinder all done outside to keep the grit out/off of the machines. It was 99º today and with long sleeves, mask and face shield it was miserable. I did use the trailer for this and the hight was good for my back.
Once done, I stacked them on a pallet and used the forklift to move back inside. The larger shop space is nice for rearranging the tables and locating the stacks of components for the next operation.
The Axel and legs are welded up using independent jigs. These two jig are by far the ugliest jigs I made, but they work very well.
No measuring required. The leg jig indexes to the cross bar and the axel jig indexes to the end.
The finished frames stacked on transport fixture to be taken for sand blasting and a powder coated (safety yellow).
12 hours of labor on Labor Day! I'm back on shift tomorrow and will be starting the handle bar assemblies first thing for Wednesday's POTD.
Honolulu request the delivery by October 10th. The powder coaters take up to 10 days and transit time is estimated at 7-10 days, hence the long work hours.
Stay tuned and thanks for looking.
Happy Labor Day!
Turn and burn!
Paco
