Finished (I thought) my ER25 collet chuck last night - checked the taper then ground it with a dremel attachment
super smooth and shiny
runout at the face on a 3/8 or 14mm round was around 0.0005, which was great, but ~8thou 6in out, which wasn't. I need to do some investigating as to why.
I modified a couple of purchaced SS bolts for a friend. He wanted the shoulders and the heads reduced in diameter. The photo is the finished work. I needed to put a center drill in the threaded end to keep things in line. Got to use my v-blocks on the mill for the first time to do that. Also first time I worked with SS on the lathe. It turned pretty good. Not a fancy project, but everything went very smoothly and the whole project only took about an hour.
Rick
Nice looking work. Suggest you put a coin (or some common item) in the photo(s) in future. You know there size, but we don't.
Nice job ncjeeper, I did that same thing with internal and external threading inserts, it's fun to make your own cutting tools
I spent part of the weekend and last two days reconditioning my arbor press. It's a 3 ton Dake.
They are certainly nice to have. I find that a hydraulic press is great to have but an arbor press is so much more convenient for small push items like shafts and bearings or straightening things a touch.Nice job on the press. I have a hyd. press, but I'm always on the lookout for a nice used arbor press. That one should serve you well. Mike
Started a set for my grinder last week but it is on hold as the wife had a bad stroke Sun. night.I've been bogged down in home maintenance lately, but was able to get into the shop last night and mock-up a new tool rest for the grinder.
