2016 POTD Thread Archive
I finished up a quick refurbish of a '50s (?) Columbian 504 vise. Really just a disassembly, de- grease, wire brush, paint, reassemble sort of thing. But man, it works like it probably hasn't in a long, long time and it looks pretty good. Backlash was 2+ turns and is now less than a 1/4 turn. It's a nice addition to the more modern Yost.
8120915442_ef458520da_z.jpg25064249890_3c92bf1aa0_z.jpg 25266787091_035a7cd2e4_z.jpg 25453689172_58984ab58a_z.jpg 25479546651_21e20d4b4e_z.jpg
Always nice to bring one back to it's former glory. I think tools, cars, and such respond to love and attention just like we do. Mike
More progress on the lathe upgrades. Took the end cover to the Mill to enlarge the bore to 2.750" in preparation for the spider build once the machine is running. I took advantage of correcting the holes center location. Needed to move the hole up .0375" as original hole was .075" off center low. The bolster has come in handy once again for quick setup for this operation. The spider will also contain the magnets for the tach pick-up.IMG_0117.JPGIMG_0121.JPG
Made a the tachometer bracket from scrap .125 aluminum. The tach will live just under the DRO and shares the same mounting bolt.IMG_0118.JPG
The last piece of the day was a milled block of CR 1/2" for the Hall sensor. The block is screwed to the carriage with two 10-24 s/s button head cap screws. I still need to radius the corner facing out. IMG_0122.JPG
Mark also completed the wiring on the lathe itself. Final VFD command logic connections are left as well as programming. Getting so close to completion, I had trouble falling asleep last night, couldn't shut my mind off despite being tired. Very stoked to see the features and options this system will provide.
More progress on the lathe upgrades. Took the end cover to the Mill to enlarge the bore to 2.750" in preparation for the spider build once the machine is running. I took advantage of correcting the holes center location. Needed to move the hole up .0375" as original hole was .075" off center low. The bolster has come in handy once again for quick setup for this operation. The spider will also contain the magnets for the tach pick-up.View attachment 124079View attachment 124080
Made a the tachometer bracket from scrap .125 aluminum. The tach will live just under the DRO and shares the same mounting bolt.View attachment 124081
The last piece of the day was a milled block of CR 1/2" for the Hall sensor. The block is screwed to the carriage with two 10-24 s/s button head cap screws. I still need to radius the corner facing out. View attachment 124082
Looking good Paco. You guys are making fast progress on the install.
Ha Ha The inside is painted. The first try at it I had some issue with my gun and got a bunch of runs. I wasn't able to wet sand them out so I had to re-paint about half of it. I'm pretty rusty and it still isn't great but it is what it is at this point. The front turned out best which is what I'll see the most so that is good. I had to pick up a cheap HF gun this morning as my good gun is totally messed up.
Sandon what paint did you use? I am going to repaint a lathe this spring and Im looking for some paint options
seasicksteve,
I used the Omni line of single stage urethane. I had most of the paint products leftover from other projects so I only had to purchase a quart of high build primer and a quart of color. I'm not a fan of rattle can paint so went with the 2K urethane. Overkill for a lathe stand but it does look good. LOL
If you have a paint gun (or just buy a cheap HF gun) another alternative is to go to your local farm supply store and they will have equipment enamel in quart cans in several "tractor" colors. I would use some hardener in the paint or it will take forever to dry. They didn't have the color I was looking for but they do have a medium gray that I will use for a grinder stand that is next on the list for paint.
I got this today. A result of Enco having their 20% off and free freight shipping.
Stupid photo wont rotate sorry.
Not so much in the shop, but inital design for a shop project.
Rear bumper design for 88 K1500.
Now to finalize design and start collecting materials....
Sent from my SM-T217S using Tapatalk
The vice re-haab in post #6511, above, reminded me of a project I did last week. Along with other equipment from the previous shop my son acquired, was a fairly new Harbor Freight 4" vise. It rattled and wandered about, just sloppy as expected. My first thougth was to put set screws against one bearing surface to take out the wander, but found it was tapered. Snug up the set screws with it open and it wouldn't close. So. I figured out the taper and put the top section in the mill vice (with half the taper up) and cleaned up that side (about .020), turned it over and did the same on the other side. It came out parallel within .001, good enough for me. I put it together and guess what, the jaw was .040 out of location, and .010 out of square. A piece of .010 feeler stock solved that problme, and a piece of 030 brass solved the other one. Now it's out .010, but you can't see it. In the picture below, you can just see the upper left corner of the brass and the right edge. I couldn't figure out how to keep it up on the wear surface without using the whole piece.
On the other side you can see the set screws (tipped with brass to avoid erosion). It now has about .003 slop.
Its hard to believe it's the same vise.
