2016 POTD Thread Archive
DSCF1569.JPG DSCF1569.JPG Nothing much, made a holder with my Grandson for some loose rotary tool bits that I had lying around.
He is 11 y old and did most of the machining by himself on an x2 mill. Most of the mistakes are mine. Tend to get slack with wood and was properly berated for it.
Hope this little post of his skill will inspire him and make use of my tools when I join the choir invisible.
John
My project for the day was to remove and replace the broken ram pinion handle on my 1967 J-head, V-ram, 9x42 Series 1 Bridgeport .
It was broken off when I bought the machine about 3 years ago. I figured the ram was stuck and I'd get around to fixing it eventually. Been using the machine ever since with the ram where it currently is.
I decided to investigate the stuck ram this weekend and logged the process under the Bridgeports and Clones heading, "Unstuck my Bridgeport Ram this evening". I figured that was the best place for the main story.
Here I'm going to talk about replacing the ram pinion handle.
As stated, the handle was broken off flush at the pinion. I removed the pinion from the Bridgeport, and clamped it between two v-blocks. I soaked it with penetrating oil the night before, and tried unscrewing the stub with a center punch and a small ball pien while tapping tangentially. I was able to get it to unscrew about a half turn, while working it back and forth but that was as far as it wanted to go.
I then center punched the ragged stub, and drilled an axial hole for an easy-out. I hadn't used an easy-out in decades, and had never been very successful, but now I was more mature and patient. Surely I would be successful.
The broken stub did indeed start to unscrew, but I only got it to go another half turn before the easy-out snapped. So much for maturity and patience!
I decided to attempt to remove the easy-out, so I drill a couple holes around it and was able to remove the broken easy-out piece.
Eventually I was able to enlarge the hole in the stub, and carefully remove the pieces of the broken handle, but not without some damage to the threads within the hole. I decided to drill and re-tap the 3/8in hole to 1/2in.
I used a pin gauge and v-blocks to align the existing hole in the pinion, on axis with the Bridgeport spindle. The setup was a little kludgy but it worked well. I'm not a trained machinist, but an electrical engineer that likes machines.
I enlarged the hole for 1/2-13. The setup held good and I got a nicely tapped 1/2-13 hole with which to attach a more robust handle. I screwed in a 6 inch long grade 8 bolt to serve as a temporary handle, while I resumed the task of freeing my stuck ram.
Pic below is the new handle on the job. I'll find or fabricate a suitable replacement with a ball end eventually.
I like your setup to re-tap the hole. Looks like a good port in a storm.
Like the creative setup you came up with. I have drilled out more than my share of broken bolts, screws,easy outs etc. Its been a long time since I broke something off in a hole but still get an occasional repair. I have also welded nuts or other items (whatever the situation presents with) to remove flush or sub-flush broken fasteners. I keep an eye out for left hans drill bits, many times as you begin to drill out they will unscrew. Penetrating oil and at times a little heat goes a long way.
Thanks for sharing.
There seems to be a kind of progression with the broken bolt thing. The first time you do it as a kid it's "oh no! now I'm F#%*!ed", then as you confront them over the years and discover all the different methods of dealing with them( heat and candle wax is one of my favorites ) it's not such a big deal, and finally as experience grows you are able to avoid them altogether for the most part. Mike
Bob, my first thought was that looks kind of tall. But then I thought about it, it save more vertical space, and puts the controls right at eye level. That earns it a big thumbs up! It also looks great. fine job.
I am very interested in how you end up liking that welder.
Mark
Very nice, that should keep you out of the dog house for quite a spell. Mike
HiGreg,
Anytime I cut on the CNC plasma, if the piece requires any cuts to the inside portion, I program them to cut first then the perimeter as the piece can sometimes shift or drop a bit resulting in spoilage. Thought I would share. I'm sure someone enjoyed your gift.
