- Jul 11, 2014
- 496
Mrs 2Volts came out to the shop with this.
"It just popped out. Can you fix it?"
Mrs 2Volts was very happy.
pete
Gotta be worth some wife points for working in the shop.
pete
That's a nice tool ! Do you have basic plans for it , and link to the china part you pulled cutters from ? The knurls look good !Subsequent to my attempt at tiny thumb screws, I decided I needed a new knurling tool. On-line the scissors type is available for $35, from India, delivery in three weeks. I wanted it now. The first knurling tool I had was a two cutter push type. My project involves knurling a 3/8 aluminum tube with a .030 wall. I figured the push type knurler would mash the tube before I got a good knurl.
I pulled the two cutters from the original tool ($4.95 from China, not worth the free postage) and made my own scissors type. It isn't complete, I need a adjusting knob, but the nut I'm using works.
This isn't pretty, but it works a treat.
The lower sample is the piece to be duplicated, the upper is my prototype. I wasn't comfortable sliding the knurl along the tube, that'll be the next advance. The knurl is better than I had expected from the Chinese cutters.
No plans, I copied an illustration from an Ebay ad, then copied the tool. Here's a link to a tool that resembles the one I sacrificed.
http://www.ebay.com/itm/MACHINIST-T...768934?hash=item2cb73cb0a6:g:WDIAAOSw44BYUI9A,
The end is supposed to rock to allow the rolls to 'float' a little, it was so crappy it wouldn't move.
I did plan the location of the pivot holes so that the most meat was bearing on the pivots.
But any two cutter tool would do, the cheaper the better. I thought to look at my cutters under a 10 loupe, it was all round bumps, can't believe it did that good a job.
I used the pins that came with the tool, they were 214, I drilled the mounting holes to .213, then chucked up the 214 pins and with a stone polished about a thou off, and drove them in the holes. The pivot pins for the other end of the 'arms' were a 1/4 dowel pin, cut to 3/8 length with a cut off wheel in a Dremel tool
