- Dec 27, 2014
- 4,094
You've got more "intestinal fortitude" than I. Should I do that, the 2" aluminum would spin wiping out my column and everything on it.
Do you think some machinist jacks would have helped stiffen-up the set-up?I was being pretty careful, the setup wasn't all that solid. I could feel it thinking about moving, especially at the bottom of the slot.
Yes, that and some clamps. But I was being lazy and really didn't need to take out that much material. Really just taking out the draft and some flash. The real point of that post was to illustrate a little outside-the-box thinking. I checked the setup by trying to the RT by grabbing it and trying to rotate it by hand and was not able to. So I went ahead with the cut. A couple of strips of emery cloth under the aluminum (grit side up) would have made a much more stable setup.Do you think some machinist jacks would have helped stiffen-up the set-up?
I finished up the part of my banjo project
Since the pivot locations are standard could you not have done the slots, just put the holes for the pivots where they go?
