Here's my POTD .. guess what it is ?
It's made from scrap save the white plastic converter nuts , bolts studding & two pop rivets threads nut . I used the lathe to turn off centre to get the hinge pare clearance when it opens /closes. Turned off 5 mm of the 4 mm thread form to make tiny spigots .& turned the knobs on the threaded spigot bars as well as the counter weight .
I also used the lathe to turn the right angle heavy aluminium letter " L 's " just to see how easy /difficult it might be using the four jaw chuck and two chuck keys to set the centres I used .
It's been an interesting exercise I've learnt a lot .
Horror of horrors .......... I also broke a 2.8 mm twist drill in the drill press ..something I've not done for years and years & years .
Luckily I have a pair of box joint electronic engineers end cutters which came in very handy to unscrew the old broken bit out first try because there was just enough stump left to get the end cutters to grip it.
