Bodged this up today in the shop. Scrap of steel, and some 5/8" rod from the junk bin. Was going to braze it up, but ran out of MAPP gas.
Ended up welding them with the little Lincoln flux-core wire welder.
Welded it, cleaned it up a little, and drilled 2 more holes in it, cut off the extra. Ended up with this.
As you may be able to recognize, it's mounted on top of the headstock of my Atlas MFC mill, via the overarm lock bores. It's a motor mount, for this:
Yeah. It's a kludge from hell. It's the original quick-n-dirty vertical head mount I made a decade ago, but never got around to using much. Today, I had a couple of holes to drill in a workpiece for a buddy. They had to be accurately located, and the shape of the part precluded holding it to drill horizontally. After a bit of head scratching, I drug out that old mount, jimmied up the motor mount plate, and slapped the headstock off the Taig lathe on there. A bit of fiddling, and he had his half dozen holes drilled in the right places, accurately. Sorry, no pics of the job.
There's only about 5-6" from the spindle nose to the table as-is. I'm looking at making a pattern to cast an aluminum spindle housing for a much beefier, stable vertical head, using an old Taig spindle I have on-hand. This is light-duty as heck, but it worked, worked well, and netted me a 6 pack of beer. Gotta love it when a 'don't even have a doodle, I'm just winging this as I go along' project actually works on the first shot.
