2015 POTD Thread Archive
use a smaller dia. height adjustment screw and a larger dia. knurled height adjustment knob/thingy. it is just locater not a force holder.
As cathead mentioned dovetail width critical not depth
I unloaded a Bridgeport today. ..
What is on the end opposite the head? How about a little more info, is this a new to you mill, a job moving it for somebody, etc?
Maybe its just the camera angle but that looks like a beefier than normal BP.
thanks, Brian
Sorry. Yes new to me. The guy said it's a shaper attachment. I'm just getting started with machinery. Joined the forums to do research and learn. It's been in a barn for several years. Working on putting the head back on.. wow..
Kludged this up yesterday to remove some of the webworm nests in our persimmon tree. It's the nicest looking tree we have, and I don't want it to get stripped bare like it did last year.
Long piece of conduit, bamboo pole, two rakes, and plenty of duct tape.
L have found that a propane torch does a great job. A quick pass over and the web will burn but the tree will not be hurt.
Well I resurrected the scrapped tool holders, cut the initial slot revealing the partial threaded trough, tig filled them and re-machined to proper depth and cut dovetail with my homemade insert cutter. Drilled and threaded the height adjustment post holes in the correct spot this time. My plan worked. Thanks again for all the input. 4 done - 3 to go tomorrow.
Jrstech, that finish your getting looks great, it appears to me that your Mills head is perfectly trammed.
Actually it was really close - about .001" out front to back and .0015 left to right. I just re-trammed it using a new 13" brake rotor and was measuring/spinning the dial indicator 1/4" from the outside edge. It took me almost 1/2 an hour back and forth on the wrench to eliminate the differences. It now reads a perfect "0" at all angles!20150531_152836.jpg 20150531_155459.jpg 20150531_164216.jpg 20150531_174922.jpg
OK Andy, you officially suck ,
That is a hell of a find. I hope you didn't have to pay too much for it. With a little TLC you are going to have a great machine.
Randy
Note, in the machinist scrounger world, "suck" is a GOOD thing"
jrstech
Those look really good. I want some. I'm not sure my skills are up to that yet. But it is planned unless I ditch my tool holder for a different kid. There is another style I like better.
andy alford
That is a nice mill. That thing would probably make the hillside I live on slide. Lol
