chevydyl,
That looks awesome.
I have been wanting to build a bigger shower 48" x 72" but am reluctant to spend $600 on the pan for the floor.
How did you anchor it to the walls?
If it is a standard wooden floor ,you can put down a thick " balanced ( odd number of veneers ) " marine ply base and construct wall studding then coat it in a cement & fibre glass concoction boarding ( 19 mm thick & fastened to the cubicle frame work & floor with special sheradised board screws with a one way water proof membrane over the top ..
This membrane then gets skimmed over with a fine rubberized water proof cement & your ready for tiling things up .. This side of the pond it's called " Aqua board " & the membrane was I think called Deetra or Ditra
You lay the heated floor tape on top over the water proof floor membrane once it's taped in place measure the resistance etc .to ensure it is not faulty insitu . If OK carefully flood the area with another thick coat of cement to seal in & protect the tape/ heating cable ising soft rubber blades to move the cement around so as not to damage the heat cable /tape .
When it's dry in a few days time you measure the resistance of the cable again just to check as it's a bugger if you do all th expensive stuf only to find that the tape /cable has been damaged .
I used a very thick floor leveling compounded shape the actual wet area of floor into a slight dish tso it runs to the drain channel .
Did a bit of free hand sketching to work out heights right from the bathroom door so that there are no lips that will cause problems with a wheelchair or present any tripping hazards also to ensure that any water runs back inside the wet room to the drain channel .
I had to cut some thin & some thin long wedges of soft pine and used them as 1/4 inch tick screeding guides after painting them in melted wax ( allows easy removal ) before siting them & sticking them down in the right places with bits of " Five day Frog tape ".
The next day or so was spent carefully laying the shaped screed and left for a couple of days to dry.
It was so funny ,for I had to remove the bathroom door and set up a system of gangplanks so we could get to the toilet pan as we only had one loo in the home
Once dry the wooden spills were removed and I then started the floor tiling . Left it to dry a couple of days then used water proof rubberized grout to seal & grout them in .
another day or so . After this I covered the whole floor to almost the edges with two layers of very thick cardboard so I could tile the walls without damaging the floor .
As I did all the work myself I think it was just over $2,000 USD for all materials ( back in 1996 )
