2015 POTD Thread Archive
I have a rotary table, Dan, in fact a couple of them. I've always found it difficult to index multiple close tolerance holes in different parts, especially when I can't use one as a template. The new DRO on my mill makes it easier, but it is still scary.
Dan...... I see you didn't cover the bed of your lathe while turning that nasty cast iron tsk.tsk.tsk. personally I wrap my lathe up like a condom leaving only the workpiece and tool post exposed, as well as have a vacuum nozzle pointed directly at the work. Are you not worried about the dust?
While gray cast iron swarf is messy I don't see that it's more of a hazard to the machine than steel. White cast iron, on the other hand, contains carbide.
You didn't watch the entire video did you? :big grin:
About 20 minutes in I showed how I covered up the lathe for one operation. IT wasn't feasible for some of the operations, simply because the risk of protective material getting garbed and thrown about the place was pretty high. The plan for this evening is to pull the carriage & cross slide off tonight, to do some hardcore cleaning.
I'd agree with that, I probably spend more time setting up the rotary table and getting everything aligned, than i actually did using it.
You caught me, I watched it until you showed the lathe with a bunch of dust on the ways then got a phone call.... I didn't know about the different cast iron grade stuff thanks for that tip. Even with all the precautions I took on my adapter plate I was amazed at where the dust ended up, creeping it's way into just about every nook and cranny
I used a lot of frog tape to hold my covers in place, and had it setup to where when I moved the carriage the carriage wrap would follow over the bed wrap...
