Had a play this afternoon .. at making a fluted knob as I intend to make several out of aluminium with steel inserts incorporating a free moving shouldered stand off washer .
They are to replace missing cover closers that screw on threads poking out of access covers and also to replace several small " Wing nuts " that I'm finding increasingly difficult to work due to loosing sensitivity in my finger tips because of type two diabetes.
To get the flutes I used a simple high quality 1/4 shanked wood router spade blade in my lathe , making seven light passes on the aluminium bar I'd turned down at one end so it will easily fit the boring bar holder on my QCTP.
Getting the spacing's for the flutes was done using a 6 " diameter motorcycle engine timing disk that is marked off in degrees , mounted on a threaded bar I'd put in th back end of the aluminium bar. Then using a single loop of thin stainless steel wire I hung a 2 foot long thread made into a pendulum using three 19 mm nuts for the weight. Hung off the threaded bar so it was one and a half thread pitches from ( almost touching ) the timing disk.
As first flute cut at bottom dead centre ( BDC ) , loosen the clamp screws rotate 40 degree second tighten the clamp screws , rotate to 80 third .. 80 through top dead centre to 40 degrees make fourth and so on till I almost made it right round then i noticed some thing .. can you spot the deliberate mistake and work out how it happened .
The timing disk has an 8 mm centre hole :-
( I might end up putting an 8 mm holed double sided bush in here and use an Allen key set screw to hold it in place )
The hastily modified end product.:-
Well we all have to learn somewhere yet still make a few mistakes
So did you see where it went wrong & why ?
