- Apr 21, 2013
- 205
I made a storage rack for R8 accessories for my Bridgeport clone mill. I probably made it bigger than it had to be, but I might modify it to hold a few wrenches, etc. I used a 3/8" aluminum plate, 1" holes bored with a hollow core bit. For mounting to the mill, I used the two lower threaded holes for the head nod adjustment (about 1/2" of thread was exposed) The hubs that I bolted to the mill were a scrap yard find. They are bored 1" diameter, about 1.5" deep. I inserted 1" rod into these bores and welded on .375" x 1.5" steel supports. 10/32 Bolts through the plate are threaded into the .375 edge of the steel supports. The assembly is easily removed if it would happen to be in the way for an operation.
