- Jul 9, 2014
- 622
What is the easiest method you have found for cutting inside the foot and getting it to stay on? I have several that need new ones as well.
Better late than never .
On the Record G clamps that I have , the foot attaching device is a bored hole . The thin end of the foot is crimped in three places over the ball end of the screw. It's a good idea to put a glob of thick grease over the ball or down the hole before you crimp it as this can help keep the foot at a required angle when tightening the clamp up as well as lubing the foot when it's under pressure.
Crimping up on the replacement feet is is often done by having it assembled & screwed up tight . Support the web of the anvil in a big meaty vice and use an all steel square ground screwdriver as a chisel , then give it three equal distance crimps down on the foot lip so you swage the thin metal over the ball in one simple blow ( using a medium hammer )
By the way ..... Record clamps are usually coated in a vibrant " Royal blue " colour as shown above
