2014 POTD Thread Archive
A friend is restoring a 100 year-old cider press and needed a part made he could not find. The original is cast iron. My version is 1018
sent from my hand held hickymajig
nice is that just a radi or is it a ball socket?
Made some V Plates for HF vices.
3/8 plate, 1/4x20 bolts
counter bore
Need these for holding rods, welding, notching ends, tapping.
Have a nice wilton vice, not going to change anything on it.
Charl
Had a friend come over and needed his PTO rebuilt on his garden tractor. The bushing that presses it out of operation was worn out. Its sposta be made out of a fiber and wear on the steel bushing in the center of the PTO. For years people have been making them out of brass, a forum member here dose it, so I tried my hand at it today. This is the second thing Ive made on my new to me 9A.
Here is my POTD.
I made an indicator holder for my drill press: the small plastic piece is a morsel of Delrin, ⌀ 10 mm, with an 8 mm hole reduced to 5 mm in the bottom.
This was made with a drill press, since I've nothing else; the outside of the bushing has a dark ring because I cut it with a pipe cutter.
I'm sure many beginners will find pretty difficult to make a concentric hole like this one, so I gathered some basic instructions into a single image: click on it to see the larger version.
For who is browsing with a phone, here is a more readable text description.
1) Get a second chuck. A threaded one is better, because you have to bolt it to the drill table.
2) Insert the bit you have to use in the drill chuck, keeping it very low (grab just the tail of the bit).
3) "Hang" the second chuck to the drill bit. Don't close too much the second chuck, just to
avoid it falling down, or you'll damage the bit.
4) Move the table until you can bolt the second chuck into the table hole and lock both the table and the second chuck.
5) Remove the drill bit and place the piece you have to drill into the lower chuck. If the piece is short add a shim below it, inside the lower chuck.
6) Put the drill bit back into the drill chuck, pushing it at the top. Hint: open the drill chuck at its widest, so you have more clearance to insert the bit.
7) Drill as usual and don't push too much!
I made this many times, always with successful results (here is why I can't persuade wifey I need a lathe!!!).
Anyway, here is the prosecution of the POTD.
I'm sure someone will ask how can I tram that small vise with such a monster… but this long setup is for the table I use for woodworking:
The chrome bars come from one of my preferred hardware shops (don't remember if Trash Depot or Dumpster Freight) and they are pretty useful. They move on a slotted plywood table bolted to the drill table and behave like a sort of very wide vise. I can even use the holes to clamp down the pieces like on a table with T slots.
I know the aluminum pipe is not the best thing for the indicator holder, but this was just a beta version: I must ask a photocopier shop some more robust steel bars (and use two or three of them).
I recently bought an Enco reversible 3-jaw chuck for my Griz G4000 9x20 lathe. Spent some odd hours over the last few days and completely disassembled it, cleaned out the grit, lubed it, re-assembled, machined the backplate, etc. etc. This is my first reversible 3-jaw chuck, and while playing with it, I realized that I'd have to keep TWO tools with it, not just one. The jaws are held on with 10mm socket head screws that require an 8mm hex key.
Then I noticed that my ball-ended 8mm hex key was about the same length as the crossbar originally pressed into the chuck key. I also noticed that the crossbar was slightly under 3/8" in diameter (knurled to a bit larger where it pressed into the body of the key), and that the hex key was .354 across the peaks (just slightly over 11/32") :thinking:
Today's project: Visited my favorite hobby shop and bought a length of K&S 3/8" OD (.014" wall) brass tubing. Cut off a 1 1/4" length and pushed it into the chuck key body. Then with my vise set to just let the 8mm key slip through, I carefully hammered on the key until it was nicely centered.
For now, I've goobered on some cherry flavored Loctite to hold things together. If that doesn't work, I'll probably have to try brazing (though I'm a bit concerned about what the heat will do to the hex key).
Anyway, I now have a single tool that will loosen/tighten both the scroll and the jaw retaining screws.
A great idea, one that I will copy.
You could drill and tap it for a set screw on the end, that way if you break, bend or strip the hex key you can change it out for a new one.
Chuck
Plus, the short leg of the hex key can act as a crank handle to speed up opening of closing the jaws. :)
Ken
