- Jul 20, 2012
- 1,263
Good work on the Arbor Press. New ones can be had at Harbor Freight for about $40 if I recall.
One trick with those is to mill off 3 teeth at the bottom most part of the ram. You would never use these teeth to press because they only engage at the very top of wide open. BUT what it allows you to do is raise the ram and at the top adjust the drive arm to your desired angle for pushing down because wit those teeth milled off it allows the gear to free wheel around with the ram all the way up, still not able to pull out with the rest of the ram still intact. Sometimes you are pressing something and the angle of the arm to push is not ideal for a good press down on.
For example look at the pics of that nice Dake. If your part happened to be where the push arm was oriented like it is in those pics vertical it is harder to push down for a nice press but if you could see that and then lift the ram up, spin the arm 90 degrees and have it horizontal it would be nice and easy.
