- Apr 8, 2013
- 2,041
If memory serves 7024 is a contact rod.Try using 7014 "contact rod" welding rods. The flux is rigid enough to maintain the proper arc distance as you drag it across the welding surface. Allows a ham-fisted welder to look like a pro. (Little skill is required to make a very good looking bead.) After each pass, one has to break off the flux to expose the electrode in order to re-establish the arc. Dragging the rod across a cement floor (or a small piece of Hardie cement board on your welding table) will do the trick.
The Harbor Freight electronic welding helmets (under $40 on sale) are wonderful for a new or old weldor.
