Got my Marquette stick welder working. Bought it off CL for $100. It dates probably to WWII. The holdup was putting in a 50A circuit and new wiring and an outlet as it has a lot of horsepower.
It came with a ton of electrodes so I've been burning them yesterday trying to get the hang of stick welding. The electrodes stick to the steel a lot on first contact but once I get it going it lays a heavy bead of weld and is a joy to use. Guess I just need to practice more.
I tried a plain coathanger to see what it would do and it fried the coat hanger in half a second
How did you turn the cam, did you use a four jaw chuck and offset the round stock first, then reset it and turn the other portion of it?I finished my first-ever project turning any kind of steel at all (newbie alert). This is a cam/follower mechanism to lock down the tailstock on my Rivett watchmaker's lathe. I turned everything on the Rivett, since (for now) it's the only lathe I have, but there's a chance I'll be scoring a Myford Super-7 sometime soon.
All parts are turned from 1144 stressproof.
Handle was press-fitted into the cam's shank. Handle's post was .140", hole was #25 = .1405". The fourth picture shows the tailstock loose, the last picture shows the locked position.
View attachment 57451View attachment 57452View attachment 57453View attachment 57454View attachment 57455
