0
09kevin
Forum Guest
Register Today
Charl, what type motor do you have on your saw a cummins turbo diesel and a piranha tooth blade :lmao:. That's some heavy stock, Good Job!Loaded up my 4 x 6 saw, cut some heavy metal. Took about 30 minutes.
Charl
im pretty sure that the interference ws caused because that is not the correct mount for the plate. my 10l came with that mount i thought it was for a light or something? the mount that was used for the stock collet rack looked alot like the clamp used on the taper att. but with a tapped hole on the top before the section that had babbit poured into it
