Today i continued working on the little niva, Started with the rear diff, replacing the pinion seal. It was leaking so i installed a new one. Old one lasted nearly 40 years. I also changed the oil in it then moved on to changing the heater core valve. The old one has rotted away so i installed a new one i also used lots of hi temp silicone, i still need to install it in the dash.
