Last few days i've been so busy working on others vehicles and my 2 full time jobs. I finally had few hours to work on the little niva. The plan is to start the engine. Started with the wiring, prime the fuel system took off the air filter lead to see if the carburetor is spraying fuel, its not accelerator pump is probably shot. I did install the battery and turn the key to see if the wiring is any good and on the very first revolution engine fired up, vacuum line for the brake booster was open so it was idling rader high but i fired so fast i wasn't expecting it, because of the oil when assembling it smokes a lot, and the oil pressure took a solid minute or two to come up. It runs i still need to adjust the ignition and carburetor but i need to assemble the cooling system first so i can run the engine for more than 3 min. It seams to be more responsive now, that incrise in compression might have some ting to do with it.
