No 16v are the newer computer control HDI common rail engines, i'm using a mechanical injection engine they are only 8 valves. Citroen and peugeot are same corporation, they have the same engines, it's easy for me to find them because i know them so well, i've had so many over the years. Diesels are torque monsters, stock 1,9td makes 90 Hp and 200 Nm the weight should be the same maybe lighter on the N/A then the factory Lada gas engine, they are both cast iron block and aluminium head, peugeot unit is newer design so is more compact and lighter also much more reliable.
Lada engine 1569cc 75hp 128Nm
Peugeot diesel N/A 1905cc 64hp 138Nm
Peugeot diesel turbo 1905cc 90hp 200Nm
