I've been exploring all the aspects to improve the little's Niva engine performance, with the LPG i can regulate the fueling pretty good and i'm around 11,5 to 13 AFR thru the rev range but the engine doesn't want to rev and make power above 3500 rpm, when i started to drive it it won't rev past 2500 rpm with driving it got better but still isn't right. It starts to make more noise and vibration above 3500 sounds like valve train noise. I'm pretty sure is not pre detonation, i can hear an engine pinging and this is the opposite of that. Can it be lack of ignition advance, the distributor is an old type with mechanical advance wich could have sized, any knowledge or experience with ignition advance and testing is much appreciated. I want to avoid replacing the entire ignition system if i don't need to.
