- Feb 2, 2013
- 3,916
Hi Genec,go look what robenz did to his good idea
i'll be sure to see robenze did, thanks for the suggestion!
Thank you Karl,A pic is worth a 1000 words. I mounted a 5hp 1750 motor INSIDE the old 3hp DC motor. There a chain coupling where the old DC shaft was cut. i put the speed pot on the same speed control linkage, same with the forward off reverse swtiches. can not tell form the out side it has a rebuild. FWIW, I've run this machine up to 4500 RPM many times - a bit more than most say is safe for a 1750 motor
..., but i doubt i will ever turn it to 4000 rpm
Very nice machine and what a score. As Karl and others have mentioned, a lot of information and very knowledgeable folks in some of the other forums, like PM. I have seen a number of 10EE discussions on motor/VFD replacement in different postings, in this case since all the control systems are removed, a VFD is the way to go. If using a single speed motor, what other have indicated is you need at least 7.5Hp and possible 10Hp; with the back gear, then 5Hp works well. If you have/use the back gear, then there is information/postings on different ways of mating it to a new motor. I like what Karl did, haven't seen that one before. You might look for an inverter motor, the one below will go to 6000 RPM. A couple of months ago I saw a Marathon BlackMax 5Hp going for $150, it was a steal. You may be able to work on different shippers to get the cost down, these motors are heavy. Otherwise a standard inverter (VFD) rated 1750 RPM motor would max out at around 2700RPM (90Hz). A flange mount may be more ideal if you are going to make some interface plate between the motor and gearbox.
https://www.ebay.com/itm/Baldor-Rel...P-230-460V-1760RPM-3PH-IDNM3665T/182487935288
https://www.ebay.com/itm/M3665T-Bal...-TEFC-230-460-volt-3-phase-motor/152731002102
