1" round rod, what can be made?
Found a 10' long section of round steel 1" in diameter. I cut off 12" length and cleaned it up a little, as it was buried in the dirt of my backyard.
I was thinking maybe a hammer but it looks like most machinist hammers use a aluminum handle.
What sort of stuff would you make or could be made from a 1" steel bar? With lathe only, no milling here, yet.
Use the T-slot nuts to hold an angle plate on the cross slide. Then you can attach work to that and use the lathe as a simple mill if needed.
Robert
Make a spring loaded tap follower for using your new taps. Great project and a lifetime tool you will always have and use. 6 inches for the body and 4 inches for the plunger with a 45 degree point1535244816205.png
Then your whole life you think “I made that myself out of steel dug up in my backyard.”
Just saw it up to manageable lengths and keep it for projects as they come along. I try to collect as much of that sizes of steel just to have. You always need stock.
