very very busy with that work crap.. but did manage to make a period correct push-pull throttle valve,, the original would of had a sliding plate,, due to scaling down the plate was replaced with a piston,, seems to work testing with air, will have to see with steam,, there is a drum type that would also be correct. I can modify some existing proven scale throttle plans for that type if needed,, slim seems to think wide open is the only position..
