1/6th scale 1890's 30ft navy steam cutter (live steam)
the micro cutters arrived, won them off the auction site for 5.91 shipped,, they look unused.. should work very well on the unimat SL..
milled drilled ant tapped the crosshead pivots.. put the crank rods back on the crank to check alignment of piston rods, cylinders and crossheads.. everything turned and stroked well.. profiled the pistons to match the covers,, measurements can be made for the piston rods, did a max piston travel test and compared to the engines stroke all is looking good..
made the set of piston rods to replace the work rods the pistons were on,, added some extra holders for the unimats QCTP,, including a 1/8th inch for the micro cutters,, the new cutters made the piston ring grooves fun work,, they worked quickly and precisely and the pistons were completed.. only have a few more parts to left to make.. used the block and steam chest as "ink blocks" and stamped out the patterns on gasket paper,, in looking through my tools found that some micro gouges from model dockyard cut nice small fuzz free holes...
Its about time you fed your apprentice, he's loosing too much weight.
slim's weight has been very constant.. he does say food and drink goes right through him.. hot and humid here today, spent a quiet morning making gaskets...
started final shaping work on the engine bed,, knocked off the hard corners on the bearing blocks.. needed to make a some jigs to mark,punch,drill and tap the thrust box mounts,, turned and drilled a shaft section to give a good center point to work from,, milled a block to support the bed and mounts while the work was going on.. still making it up as I go along..
machined up the thrust box castings, mounted it up, drilled and reamed for the shaft..
That is amazing. Cant wait to see more pics and it actually running and sailing.
