- Apr 14, 2014
- 3,161
Also don't forget to proofread your post after posting it. I have had "autocorrect" also known as spell check mangle some posts and make them almost unreadable. There are times when I've had to edit and repost them multiple times before the corrections would be accepted. There are still few posts I submitted that have gibberish in them because I didn't proofread them before they timed out.
Also keep in mind the part about what are being referred to as "contextual" errors. An example I'll never forget was back in the 1970's when I was taking a refresher course for NAISE (now ASE) certification. One of the questions on a sample test was: What is the most common cause for an inoperative turn signal or parking light bulb? Every member of the class responded, "burned out bulb". The instructor marked them all wrong and said the correct answer was "bad ground".
No one could believe it, so during a break we all decided to keep a record of the number of incidents, and their resolution we encountered during the next few weeks. The week the class ended we presented the information from our experiences to the instructor. Over a time period of a month collectively the class (25) members had experienced 18 incidences of inoperative turn signals and parking lights. All of them were cases where the bulbs had burned out.
In our very local and uncontrolled sample the bulbs were not only the most prevalent problem, but the only problem. However, a national survey being used by the instructor found that in a larger sample bad grounds were more prevalent than burned out bulbs.
