- Nov 25, 2015
- 8,314
why not just order a rebuild kit for the jaws.The albrecht chuck that I use in my lathe is old and the jaws are probably too worn out , maybe that's why I find it a PITA to use in tailstock, if I need to use a drill bit anything over 1/4" , I usually go with the keyed chuck so I can crank the key in 2 spot, the ER 32 collets should clamp much better and as mentioned above more accurately than the conventional chuck .
