- Feb 8, 2014
- 11,144
As far as replacement motors go I would like a single speed 1800 rpm. I assume 1750 would be okay if significantly cheaper? Under 10A. And the same bolt mounting pattern. Anything I am missing here? Thanks again.
A typical 1800 RPM @60Hz (nominal) actually turns at somewhere between 1725 and 1750. This is due to the internal slippage in the magnetic flux. So you will find most 4-pole motors rated at 1725-1750.
