Can you update me on any specifics that helped separate the cases? I have read the above posts after running into the same problem today. The right side gearbox cover on a 1970 Triumph is glued down shut. It is a beautifully restored bike, and there are no lugs or projects on the cover to tap on. The joke is that just this morning I told a man 'you can take apart anything with heat, vibration, and patience.' Look what the hubris brought me!Success! Thanks guys
