    Dismiss Notice
Y Axis Power-feed For A Benchtop Mill
Discussion in 'PRECISION-MATTHEWS' started by Dan_S, Mar 21, 2016.
  1. Dan_S
    Dan_S Active User Active Member
    538
    93
    City:
    Champaign
    State:
    Illinois
    -Return to Top-
    Anyone set up a y axis powerfeed for a pm-932, pm-45, pm-940 etc, if so what did you do/use?
    After all the cranking I did in my last project, I'm thinking this might be a good investment to save me time/hand cramps. :D
    Fitter Bill likes this.
  2. wrmiller
    wrmiller Chief Tinkerer H-M Supporter-Premium
    945
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    Hey Dan,
    Does the Y-axis handwheel and bearing plate extend off the front of your stand? Reason I ask is because when I had the 12z, mine did (not counting the chip tray), and I was seriously considering buying a standard Y-axis PF for a knee mill and making a custom front plate/bearing carrier and shaft extension if needed. But as you know, other events happened that eliminated the need for this project, i.e., bought a new PM935, so I never got past the planning stage.
    But I was pretty certain that I could make one work. Now if the Y-axis handwheel doesn't extend beyond the mill's base, then this scenario won't work.
    Just a suggestion. :)
    Dan_S likes this.
  3. Dan_S
    538
    93
    City:
    Champaign
    State:
    Illinois
    -Return to Top-
    Yea, mine does you can see it in these photos, the handwheel is out past the chip tray even.
    [​IMG]
    [​IMG]
    wrmiller likes this.
  4. coolidge
    coolidge United States Active User Active Member
    841
    113
    City:
    Battle Ground
    State:
    Washington
    -Return to Top-
    I purchased a 2nd power feed for my Y before thinking this through, in the end I decided while it was possible it would require more engineering and fab than I wanted to mess with.
  5. wrmiller
    945
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    Dan, Charles is right in that this would take a bit of thinking/engineering and fab, but I don't think it would be that hard once you get into it. From the pics I would say it's definitely worth looking into.
    EDIT: Look at it this way. Once you figure out all the details you could offer your services to others with these machines and maybe get a bit of walking around money for your efforts. ;)
  6. Dan_S
    538
    93
    City:
    Champaign
    State:
    Illinois
    -Return to Top-
    I know it would be work, my main concern would be making sure I don't loose any travel. I might have to email Matt, and see what he has to say as well.
    I found a video series of James Kilroy's and he did something similar.
  7. navav2002
    navav2002 United States Iron Registered Member
    20
    3
    City:
    Cartersville
    State:
    Georgia
    -Return to Top-
    I am planning a Y axis power feed for my 932. Searching eBay for "Y axis power feed" will yeild several results of kits that you shouldn't have to modify very much as they come with the Y axis components. They appear to be different than the X axis kits.
  8. navav2002
    20
    3
    City:
    Cartersville
    State:
    Georgia
    -Return to Top-
    Looking at things a little more closley, I'm thinking which ever kit you start with you will need to do some modification....It may be easier to start with the x-axis kit so you get the mounting plate??
    I was planning on ordering one of the aSong kits next week and giving this a shot...
  9. navav2002
    20
    3
    City:
    Cartersville
    State:
    Georgia
    -Return to Top-
    I'm finally getting around to installing my Y axis power feed!! As with any project like this there are several ways to "get there", I thought I'd share what I've come up with, hopefully it will give you some ideas on how to proceed. I don't think there is a true "bolt on" kit available that will fit the benchtop mills, every kit I've seen will need some sort of modification as they are really designed for knee mill instillation. I am not done yet (am waiting on a part) but I will show you what I have thus far:
    I made a stand off and a spacer to clear the drip tray on my machine.
    The spacer replaces this factory part.
    I also extended the shaft.
    So it looks something like this:
    I bought the wrong power feed...This one is designed to be mounted horizontally (that's why the top is chopped off rather than rounded}. Don't get this one, get the one designed to be mounted vertically... :)
    I will post more when I'm finished...
    darkzero, RIMSPOKE, burtonbr and 4 others like this.
  10. wrmiller
    945
    113
    City:
    Hereford
    State:
    Arizona
    -Return to Top-
    Nice! Yea, when I saw the last picture, I was like 'oh no, that's for the x-axis!' but then realized that you had it figured out already. You could always fab a small cover to protect the gear from chips and whatnot. :)
    navav2002 likes this.
  11. burtonbr
    burtonbr United States Active User H-M Supporter-Premium
    44
    28
    City:
    Sandhills
    State:
    North Carolina
    -Return to Top-
    That's very clean looking install I bet your going to enjoy it..
  12. Silverbullet
    Silverbullet Active Member Active Member
    700
    113
    City:
    Marlton
    State:
    New Jersey
    -Return to Top-
    An old timing gear cover from a kohler engine is shapped just about right.
    navav2002 and tweinke like this.
  13. tweinke
    tweinke United States Active User H-M Supporter-Premium
    234
    43
    City:
    Fairmont
    State:
    Minnesota
    -Return to Top-
    That would be repurposing at its best!
  14. WHKAMP
    WHKAMP United States Iron Registered Member
    7
    3
    City:
    Dallas
    State:
    Texas
    -Return to Top-
    This is my version of a Y axis power feed for the 932.
  15. WHKAMP
    7
    3
    City:
    Dallas
    State:
    Texas
    -Return to Top-
    Thanks to all for the nice comments. A few more details on my Y axis install. The calibrated dial is from the junk box but was from an old Bridgeport, these are available on Ebay. The hand wheel handle folds up, I could see possible bodily injury with the OEM Y axis crank handle spinning around! These are available from Grizzly and others.
    Installing the drive is one effort, rigging up the limit switches another. The picture shows how I did it. The micro switches need to be swapped one side to the other which can be done without disturbing the wiring.
  16. navav2002
    20
    3
    City:
    Cartersville
    State:
    Georgia
    -Return to Top-
    My parts came in so I got to make some progress on my Y axis power feed. I still have to install the limit switch but other than that I am up and running. I really love this mod!! It makes life so much more enjoyable and gives you a better finish to boot!!
    Here are a couple more pics:
    I cut a keyway slot and pinned my shaft extension:
    I also modded the bevel gear to accept my handle:
    I made an alumnium cover since I had bought an X axis power feed...It's kinda nice as I was able to gain a little more travel by milling the cover in this fashion...
    wrmiller, Dan_S and tweinke like this.
  17. Dan_S
    538
    93
    City:
    Champaign
    State:
    Illinois
    -Return to Top-
    Excellent work, when I get settled into the new shop i will have to add this to my project list.
  18. navav2002
    20
    3
    City:
    Cartersville
    State:
    Georgia
    -Return to Top-
    Thanks Dan..
    Whkamp makes a very valid point above...You need a folding handle for sure!! It's very uncomfortable having that meat cleaver spinning around your groinal region...
    I will probably change the handle to a folding version or remove it all together...I doubt I will ever use the handle, the power feed is controlable even for finite adjustments...I never use my X axis handle either...
  19. WHKAMP
    7
    3
    City:
    Dallas
    State:
    Texas
    -Return to Top-
    Very nice work, the mod to the bevel gear housing a great idea. For those contemplating the Y axis motor add, the top of the bevel gear housing is higher than the bottom of the table and this limits the table travel unless a work around is implemented.
Share This Page
