WTK Good led light for PM835 mill
One thing to consider is to have at least two or more lights to decrease shadowing. Also adding a spindle Halo ring light helps a lot. I use a 2 foot LED fixed light bar and a ring Halo light, so plenty of light and no problem with shadows. These are usually 12VDC but some operate over a range of voltages. Example of a light bar in the link below with aluminum body and glass cover. Make sure you get lights with a cover lens. The ring "Halo" lights are very common, usually one will get a set of automotive Halo lights, one can also do a ring within a ring for more light. You want a high output light bar, so the one below is listed at 10W or about equal to an 80-100W incandescent, mine is an industrial type that I picked up for $30 but listed at much more. Added advantage is they run cool and stay out of your way.
https://www.ebay.com/itm/Lunasea-Mu...Bar-48-Cool-White-LEDs-24-LLB-32/272959702301
I bought one, Tom, and find the light a bit weak. It is handy to place on machines, though.
Bob,
Did you buy the 20 LED model or the 10 LED model? I bought two of the 20's, mounted one one each side of the head to eliminate shadows and I find them to be more than bright enough. It may make a difference how they are positioned and on which machine. Mine are on an LMS 5500 (SIEG SX2.7). May not be enough for a larger machine.
Tom
Edit: Thinking back, I do remember the shadow was bad with just one light mounted, but the second light took care of it.
Mine has 30 lights, bought because of a recommendation from someone on H-M (you?) a few months ago. I used the link supplied to buy the light, though the seller may have pulled a bait and switch...
Bob,
I went back and found the thread that you may be talking about (last August) and woodchucker said he had a similar 30 LED light that he was disappointed in. Maybe the same light you got.
Tom
Bob,
Tom
Well, it was cheap, and it works...
Bump for any more insights on a good ring light for the PM833? Thanks in advance for the help!
Mark -
How did you attach the LED ring to the mill?
