- Jun 17, 2012
- 2,220
As some of you may already know, I purchased a 20x40 Ikegai A20 lathe. It was delivered 1 week ago today. I set it up and got work for it 2 days ago, and I've been doing paying jobs on it for 3 days now.
I'm having a blast with this machine. At first I was treating it like my it was my 12" lathe, taking light cuts and really going easy on it until I got comfortable with it. I quickly learned that this beast can make quick work out of some rather beasty parts.
Some pics of the work I've been doing.
2 1/2" spade drill ripping thru a piece of stock. The tail stock can be driven in a 1-1 ratio like a regular tailstock, or a 5-1 gear reduction for pushing those heavy drill bits through. The 5-1 gear reduction makes easy work out of those large holes.
These are semi finished parts that need to go back to the grinding shop for final grind sizing and some bolt holes need to be drilled in it.
The next 2 parts I have to make are each coming out of an 8" diameter x 9" long chunk of steel. These will also be ground to size and holes drilled after I'm done with them.
Shimming it up close so that I can chuck it up into the lathe. These are some heavy SOBs. They've gotta be all of 150lbs each! Chucking it up is a total work out.:nuts:
Chucked up and running within .010". .010" is close enough for these chunks I'll have them running true on the first pass.
Faced center drilled and running in a live center. Here I'm taking roughing passes, .300" @ .033 feed rate per revolution. The machine is eating it up and I'm getting a perfect straw colored broken up chip.
This side is to size and a 2.25" hole is being drilled all the way through the part. It took about 15mins to drill the hole.
Ready for boring to size.
I'll post more as I move along with these hubs.
Marcel
Marcel
