I am trying to drill a 9/32 hole about 3" deep (800rpm) between two 1/4" cold rolled plates sandwiched together. It drilled easy and had good chip flow for the first 1 1/2" then just stopped cutting. It just squeals and heats up, no amount of force will start it cutting again. I have tried brand new bits (1/4 and 9/32), tap magic, oil etc with the same result. So, did I do anything wrong or could there be some hard material in the metal? How would you suggest I complete the hole? Carbide / masonry bit?
