- Mar 19, 2014
- 2,681
One important feature of a woodruff cutter is it does little or no cutting on the sides. It makes a slot the width of the cutter. Milling a slot to a close tolerance for a key to "fit tight" with and end mill is not easy. It is much easier to get repeatable dimensions in width with a woodruff cutter than with an end mill…Good Luck.
