- Mar 18, 2011
- 243
On a project for an edger shaft I have to make that is no longer available for purchase, I need to cut a keyway for a pulley that has a built-in (or somehow attached) woodruff key. I was originally just going to use an end mill because I don't have any woodruff key cutters but I kept wondering if it was important or not that the slot ended in a curve. The .250 slot starts on the end of the shaft and is 1 inch long so the pulley actually slides on with the woodruff key in the pulley as opposed to the normal way where the key is in the shaft. Then I read somewhere about the curved end being better when the keyway goes up to a shoulder (which this does not) due to stresses where they meet. So, I think a regular end mill cut slot will work fine, but wonder if the original design was to make it stronger, or because they were set up with a woodruff key cutter and it was not even an issue? Thoughts?
Thanks,
schemer
edit: After thinking on it, I am going to buy the woodruff cutter and use it as it is the better way to cut a keyway anyhow. An end mill with a two flute cutter works ok for the most part but I may need to start a woodruff keycutter collection to add to my tooling. :whistle:
Thanks,
schemer
