- Jan 25, 2015
- 2,558
I've been back and forth on buying a lathe. I was talking myself up to a new lathe in 10" size, but I can't justify (or comfortably afford) the prices they go for (1500 and up).
I have been watching for used, but its mostly too big, too expensive or too beat up stuff that shows up.
The busy bee tools 7" Asian lathes are pretty much big enough for everything I want to do (ie: bushings, spacers, etc) except for one thing I'm not sure it can handle.
I need to buy wheel adapters for my cars. They are built like so:
The spacer is 6061 aluminum, but the OD is 6" and approx 1.5" thick. Fairly simp!e piece and i have the skills to turn them out. To have them made in the custom size I need is going to be approx $500-600 (maybe a little more, won't know until I get a quote).
The lathe I'm eyeballing is the Busy Bee/Craftex CX704 (http://www.busybeetools.com/products/lathe-mini-7in-x12in-1-2hp-cx-series-csa.html) which is a 7x12 and will cost me somewhere in the 800-850 range once tax is added.
So to buy the lathe and build the adapters is only going to be a somewhere in the $200-300 more range than just buying the adapters. If i buy the lathe, when done I still have the lathe to use for my other small bits that I do infrequently.
The question I have is if the 7" lathe is going to be capable of holding and working the 6061 to a 6" OD?
I don't mind going slow, taking small cuts at a time and building them over a longer period of time. That's just the cost of using a smaller machine IMHO and I'm OK with that.
If the 7" can't handle it, its not as practical (financially) as just buying the wheel adapters.
Basically,I'm looking for the best bang for my buck. I'd just as soon buy the tool and build what I need. Not so much as a money savings, but to help justify the price of the lathe and have the tool for future work. If you get where I'm going with that line of thought....
