- Aug 15, 2013
- 2,114
I may be wrong (I was once before ), but my guess would be that the inconsistency is in the ratchet, not necessarily in the measuring mechanism itself. Have you tried repeating measurements by feel without using the ratchet? You should be able to feel just the slightest resistance before the first ratchet click. Zero the mics at that point and repeat your measurements. Relying strictly on feel with both mics, do the Shars readings still consistently disagree with the Starrett readings?
Tom
Tom
