- May 16, 2016
- 1,695
Perhaps a pump of a multi cylinder engine, with all ports going into a manifold, just have to make sure the diesel is clean those pumps hate dirt even fine particles. They also hate water. If you could get a pump off an old truck, get the filter as well and put a new element in it. drive it with a high speed electric motor, probably need a few HP.
An old semi I drove years ago used to get 5 mpg so at top speed say 50MPH That was at 2500 RPM, but you could run it faster than that probably double that's about 10 gph should be enough. Find out the size of the injector nozzles and multiply that by how many injectors, mine had 8, and that will give you a nozzle size.
