I have a pm1228 lathe and I have not been able to get consistent results with with my DRO reading when making cuts. I measure the stock when I chuck it up and set the x value on the DRO. I then make a cut say .020 in depth and remeasure. The DRO then reads .0015 to .002 less than the measured reading. Is this to be expected with that depth of cut? If I take a real light cut then the DRO seems to be more accurate. I measured with 2 different calipers and a micrometer and they match.
