So, if I wanted to clean up my connections in my breaker box and put dielectric grease in there as well, what is the safe technique for doing this?
The
"safest" method to do so is simply remove the meter. If you called an electrician, that is what he would do. That kills
everything from the bottom of the meter can out.
However, there are a few problems even with that. Particularly with the power supplier. If you are in
GOOD STANDING with the power company, having paid your bill regularly for several years,
AND code authorities are slack
AND the power lineman is not an a$$,
AND you have not cut the seal on the box for a while, you
MIGHT get by with it. I have done so several times, but have lived here 40 plus plus years, have a rather "cum se, cum sa" power supplier, and did the original rewire under a permit myself. If you have a disconnect switch, common in
some locations, just pull the switch.
What it comes down to is that when you have met
all of the above, plus a few others that depend on location, and cut the seal on the meter can, the next time a meter reader or lineman comes by, the missing seal will be noted and possibly reported. A second seal, of a different color will be placed and a closer watch kept. If
that seal is cut within a year or two, you will get a padlock. If
that is cut, all I can say is "Good Luck" in the forthcoming court case.
Under
any other conditions, the inside of the breaker box will be hot. There will be some protective panels and the general arrangement of hot wires will protect against contact, shocks, but are in no way absolute. Consider anything behind the panel as a shock hazard. A breaker can be turned off and removed from the panel. Once it is removed, it will be considered safe to touch. Unless there is a "cross feed" or other shenanigans from an inept modification. So double check after the breaker is powered off that there is no power from the terminal to ground. Only then, snap the breaker out of the panel. You are now free to do whatever is required to the breaker terminal in hand.
To apply the grease, loosen the screw and remove the wire. Squirt a
little grease and and stir it around. Squirt a
little on the bare wire and coat the exposed conductor. Avoid a glob that would transfer, the grease
is conductive. Reinsert the wire under the terminal clamp, specificly how will depend on the breaker brand. Tighten well but not overstressed. The expression of "two snaps and a grunt" will be too tight. Replace the breaker in the panel, watching how the wire is dressed. If you encounter a double pole or "piggy back" be sure to do one wire at a time so the connections are not crossed up. Once you have done all except the mains at the top (usually), replace the panel. Do not do the mains, period.
Call a licensed electrician to do them, hot or not. Remember to grease the white wires where they are located on the "neutral bus". Keep in mind that these wires will likely be hot with the power on. If the panel is not dead, simply tighten them. Do not overtighten them, same as the breaker screws.
If this sounds
complicated and dangerous, that's because it is. That is one (of many) reason electricians charge such preposterous prices. Your asking how to do it leads me to think you are not competant enough to do the job. I am not saying that you are incompetant in general, but electricity is a very complex and detailed subject requiring years of apprenticeship to wire a house. Industrial knowledge and troubleshooting is even more so. I have well over 50 years in the field, and only know some aspects. The "code" is for people that know what they are doing to start with. If you want to consider this as a disclaimer, please feel free to do so. I was mastered (Fla, ~'74) for a while but now grossly out of date.
Bi11 Hudson
Master Artificer (Ret)
