- Apr 23, 2018
- 6,550
Last time that happened to me, I tightened up the grounds on the bus bar and found some had come loose. Problem solved!
If there is aluminum wire going to the branch circuits, you should check the outlets switches and light fixture connections and bring them up to code if necessary. Aluminum wire can be a fire hazard if not properly installed. See attached pdf for more info.There was a lot of aluminum line BTW.
Good point on the neutral link being criticalI don’t claim to be a NEC expert, and ground vs. neutral nomenclature can be confusing. But interestingly, NEC seems to allow 25 ohms to ground, although 5 ohms is considered good by some standards. Even at 5 ohms, a 10 amp current imbalance would mean 50 volts from zero on the neutral if the ground rod is used as the sole way of keeping the neutral bus stable. For this reason, the neutral connection to the transformer is the critical link in keeping the two legs at 120V.
Well, being therer was new siding/windows and gutters...we had our 6' sliding door removed and an 8' one put in. Popper $550 for motorized blinds as they were so tall.....3 days later the motor blew. I'm guessing this is why. My AC stopped working...I found the capacitor blew. Pretty much everything in the garage is on a UPS or voltage regulator....forgot what it's called, smooths out the highs/lows. Only time will tell all that took a hit.Good point on the neutral link being critical
A friend had a tree break the neutral support cable and the ground rods didnt take the unbalanced load the fridge fan melted when it caught fire
When voltage shifts like that happens power should be turned off until the problem is corrected
I am surprised no damage to appliances happened in this instance
