I dont know how your drum switch is wired or how it works, to connect the wiring for now you should leave it out of the equation. even disconnect it.
Have you changed any of the wiring at the contactors? According to current manual diagrams this is straight forward.
What caused you to think your original drum switch went bad? What were the symptoms? Is it possible the 3rd contactor was at fault all along?
NO one has ever been inside this electrical box til I did when I made this post. Nothing has been altered since it was shipped to me brand new in 1999.. How is it possible to disconnet the drum switch all together and the lathe still power up?
The Grizzly page shown here, says wiring has been changed at the starter switch as has the switch itself. Otherwise every thing is the same. See page here
https://cdn0.grizzly.com/manuals/g4003_m.pdf
There was no original drum switch. if you look back on the first page of this thread, you will see the other cheap clear plastic junk switches still in place
I have no idea if the 3rd (yellow) contactor is bad or not.
Here is a video.
The last 3 seconds I am pushing the start button (camera went off of subject)
Regardless of what one does right now, you have to spin the chuck to start it. and it won't stay running unless the start button stays depressed.
The buzzing noise, (like when ya push in a contactor, ) happens as seen in the video and every time you push in a contactor and hold it, if ya spin the chuck by hand, the motor runs fine. The chuck will not start turning on it's own, period. The 3rd contactor never goes in on it's own by moving the lever on the drum switch,etc
If ya turn the drum switch on, push in the start button and spin the chuck the motor runs fine.
