- Dec 18, 2022
- 1,729
It isn't about the size of your table as much as your vertical clearance. I have a PM940 and a 5" vice which came with the swivel base, under normal use I take the base off of it. In your case the swivel adds about 1.5" of height and that is 1.5" vertical height you cannot use for tooling or work piece. Just a thought.I've been looking at swivel vises, it seems that when you remove the base, you can install it on the table, and it becomes a "normal" (non swivel) base.
In other words, is there a downside to having a swivel, can you get it out of the way when you don't need it ?
