T
TOOLMASTER
Forum Guest
Register Today
your bearings may be bad?
Thanks for all the great advice everyone! I didn't get a chance to work in the shop today but I will experiment with some of the suggestions some evening this week and I will report back what I find. Thanks again!
Very good advice.Look up the optimal speed and the optimal feed for the tool and the material. Try again and report back. Best to go with what is best for speed and feed. Just telling you to go slower or faster is not the best way to go. Check the numbers and use them.
That material is not likely produce a nice surface finish ever, it tears leaving the artifacts that you are seeing. Either use another material which will be more expensive and less easily purchased or live with the finish and polish it with abrasives afterwards.
Using flood coolant and turning up the speed and feeds will also help.
