Today I was turning some 3/4" 1018 HSR using a tangential tool holder and a freshly ground "crobalt" tool. The finish was pretty good for HSR but when I looked at it closely I found randomly spaced rings several thousands deep. The finish actually looks pretty good until I try to sand it and then the rings are revealed. Any ideas of what would cause these rings? I thought maybe something was loose so I locked my compound but that didn't seem to help and the cross slide and tool holder both seem tight. I am pretty new at this and I'm not sure if this is normal or if something is wrong.
Sorry for the poor quality of the photo but it should give you an idea of the rings I'm talking about. I got these rings to show up better for the photo by sanding slightly. The rings are deep enough that I can't easily sand them out. I had to file them out before sanding and polishing. Thanks for any help you might be able to offer. If it matters, this is on a PM1236 lathe. The cut was done at about 700 RPM with a feed rate of 0.004"/rev and a 0.020" DOC (0.040" off the diameter). The cut seemed to go well with no straining or complaining.
