- Jun 22, 2023
- 328
ok first off my wife says you suck! shaper, just another tool that i don't need but now want lolFlame cuts on mild steel can be pretty tough. They will tear up almost anything on a rotary tool. A shaper is the way to go if you have one. There are few things that shapers are really good at, and this is one of them.
With a shaper you have to get the cutting tool under the dross. You also have to grind the tool in such a way that that the tip strikes first and by the time it hits the cutting edge it is already being peeled up - in other words, a positive rate.
I had to do several blocks like the one in the shaper vice in the pictures below. I could cut quite a few of them before I had to pull the tool out and re-hone it. Then I’d do another stack.
I also recommend staying away from Chinese or Indian highspeed steel. There are still a few places you can find better stuff. I’ve bought high speed steel from Griggs Steel. They have a good selection. They aren’t cheap, but it cuts way down on regrinding.
View attachment 473111 View attachment 473112 View attachment 473113
as to the cheap chinesem tooling, i hear you but there is a method to my madness i'm starting with cheap tools and equipment so i'm not afraid of tearing it up and i can afford to get a lot of stuff to try and then narrow down to the things that work for me, also i'm learning what is important to me so when i upgrade i have some idea of what to work toward. and more practice right now on cheap materials and sharpening HSS/brazed carbide is a positive right now, there may come a time when i'm working on an expensive part that needs to be precise and on a schedule but that is not now. everything i'm buying is potentially disposable if i find some stuff that works for me all the better but if i have to s#!tcan it no worries.
