- Sep 28, 2013
hey all,
I really shouldn't be thinking about this as I have far too many projects and far too little time, but the idea of making a combo belt disk sander has been tickling my brain for ages. Partly because I was given a bunch of steel and alu disks (8in?), some with a diamond coating, as they were being thrown out of the Geo department, partly because I'll soon have a spare 1/3hp motor with a 5 step pulley when (hah!) I put a treadmill motor on my Walker Turner drill press.
General plan is to have the motor behind the sander, with a belt running to a common jack shaft, which drives the disk and the bottom roller of the belt. Single pulley on jackshaft, 5 step pulley on motor and a sliding hinge type thing to both tension and align the drive belt. Sanding belt will hang off the side of a tower made out of 4 pieces of 1in.sq tubing from my old TV antenna and the rollers will most likely be ~2in wide, due to some scrap pieces I have that would suit. I won't be using one of the 3 roller+ designs as that's a way beyond my fabbing abilities.
Question is - what's a commonly available 1 to 2in wide belt size? As I can build to suit (within reason), I'd rather go for a size that a) works and b) is common (+ therefore cheap). I've heard 2" belts are better than 1", but that's about it. Also, for general use, most likely knocking edges off cuts (metal and wood) and prettying up crappy surfaces, what sort of grit would you recommend? I have a 100grit white norton wheel on my bench grinder for grinding bits.
thanks!
bah, should get back to work now
thanks!
