So it was a male-male adapter?
View attachment 48163I pretty much added what you mentioned in the OP: a POT, and a master ON/OFF switch to cut input into VFD to turn it off at the of day:as an FYI - I drilled a 1" hole on top, and one on the bottom to allow fresh air to circulate in the box (hot air goes up, cool air comes from bottom) to prevent overheating of the VFD.
No problem with heat build up then?
Do you think much dirt can get to it through the vent holes?
Where did you get the box, and are they expensive?
